Brief Description: Wing tip stiffener, fuel tank access covers
Made wing tip stiffeners from a foam block to reduce or prevent oil-canning...left loose inside tips for fiberglassing much later. Took tips and fue tankl access covers (proseal now fully cured) to wings stored in hanger. Had to shorten the fuel pickup tubes a bit with a file to get them to fit in the tank, first mistake I've seen with QB work.
