Brief Description: Started engine mount, access holes
Drilled out holes for engine mount per instructions, fits well. Had to grind down one of the nutplates holding a bolt to fill a hole in the unused fuel pump location. Rerouted the fuel line from the electric fuel pump booster to the FW to clear access holes and associated lines. Got some new access hole dimensions from Lars, drilled pilot holes but will wait until engine mount to continue. Order hardware to make access holes better.
