Finished installing the flap indicator...came out fairly well. Doesn't bind and travels nearly the full range of the device. Used double-sided tape between the elevator horn bracket and flap rod to prevent movement and additional security. Added jam nuts to clevis rod. Routed indicator 3-wire cable forward in cabin.
