Discarded the shielded cables! The sockets (and nylon Molex-looking plugs) are slightly different that true Molex female socket pins don't fit with the supplied plugs. I now remember this little problem from before. The instructions don't require shielded cable and the non-shielded was supplied by the strobe maker (Kuntzleman). So re-made the two non-shielded cables from wing strobe power supply, routed through fuse to wing roots, and attached true Molex pins and plugs at that end for later attaching to the cables coming from the wing strobes. Next is to anchor the wiring within the fuse.
