Ralph Finch RV-9A Build
RV-9A
Bottom rudder fiberglass tip
Began fitting the bottom rudder fiberglass tip better. Finished sanding bottom edge to final fit, drilled hole for wires to pass through, measured and matched-drilled holes for screws and nutplates.
RV-9A Home
2214
162
Cowl
85
172
134
193
Firewall
Fluid Plumbing
560
Garage Setup
LdgGear/Wheels
90
Plumbing
324
