Brief Description: Left Wing - Rear Spar Stiffener and Nose Skin fit
Left Wing
For rear spar stiffener, fit and drilled out to #20 (A5) to Rear Spar. Then fit trailing edge to rear spar and drilled rear spar top skin out to #30 (A4) followed with clecos.
Removed the rear spar/top rib rivit (A4) on ribs 2, 3, 4 so that rear spar stiffener can be rivited to associated rib. Also removed the three A5 rivits at root end of rear spar stiffener to that the rear spar stiffener can be rivited to rear spar.
Then refitted the top skins back in place in prep for the nose skin fitting. Steve Reynolds helped in fitting the nose skins in place. All strapped in place in prep for drilling out to #40.
