Brief Description: Right Wing - Installation of rear spar stiffener
Right Wing -
Spent at least 30 minutes reviewing all future component installations and order of installations to make sure all internal components are completed prior to final rivit installation of top skin.
Completed A5 rivit installation of all aleron/flap brackets to wing structure.
For rear spar stiffener, fitted and drilled out to #20 (A5) to Rear Spar. Then fit trailing edge to rear spar and drilled out to #30 (A4). Rivited the rear spar stiffener to rear spar with A5 rivits.
Completed A5 rivit installation of rear spar strut fitting to rear spar. Left center hole for bolt fitting.
Right Wing final installation of rear spar stiffener
Right Wing final installation of rear spar stiffener at wing root
