Cut out four L angles to make slat support bracket. Cut out slots, deburred and fitted L angle bracket to four nose ribs. Drilled out to #30 and then mounted slat support bracket and slat support for the nose ribs. Installed Corrision-X Aviation and rivit A4 assembly together.
Mounted and installed Corrision-X Aviation on all nose ribs and wing ribs on Right wing.
Also installed Corrision-X Aviation on all nose ribs and wing ribs on Left wing.
The nose ribs and wing ribs were drilled out to A5 and deburred on previous day.
Located the tie down rign. Drilled out to A5 and set aside.
