Brief Description: Left fuel tank capacitive plate
Installed the capacitive fuel sender. Drilled both T 813 to the ribs and modified the inboard to clear the stiffenersby 3/16". Installed the nut plates and checked clearances. Modified 4 snap bushings for 18ga wiring. Drilled the inboard rib for both the BNC connector and the vent tube fitting.
