RANDY'S WEB SITE
S-19
Side stiffeners
Worked on the right side stiffeners. Spent a lot of time to make sure they would line up with the skins. Used a piece of sheet metal to locate the front prior to transfer drilling. Fabbed up the required shims and transfer drilled.
Used a piece of sheet metal to locate stiffener
Had to make several shims
S-19 Home
1515
Aft Fuselage
Aft fuselage
Center Fuselage
Construction Tips
Cowling
Fuel tanks
172
FWD Fuselage
HorizontalStabilizer
Inspections
Instrument Panel
Phase I flight test
Vertical Stabilizer
Wheel Pants
326
Workshop
