RANDY'S WEB SITE
Date:  2-23-2009
Number of Hours:  3.50
Brief Description:  Upper engine mounts and gussets
Cleaned off the work table and mated the center and forward fuselage. Clecoed longerons in place, then the center and forward skins. Had to make some 7 inch blocks to raise the fuselage enough to cleco the side skins in place. Transfer drilled to 40 then 30 the engine mount to longeron. Clecoed gusset in place then transfer drilled to 40 then 30 to the longeron and engine mount.
Mating center and forward fuse
Clecoed skins to square up frame
Transfer drilled eng mount and gusset to longeron
