When placing the trailing edge in the jig the manual leads you to believe that the leading edge of the trailing edge should overlap evenly,this is not true. The rudder gets narrower at the top and the overlap is more at the top. Also where the frame sits in the jig becomes apparent once a skin is clecoed on the frame.
