Brief Description: Horizontal firewall, ELT wiring, avionics bus
Initial fit the horizontal stainless sheet for the firewall under the motor. Need smaller rivets for nut plates. Order them. Need good grommet for red cube's wire. Order some.
Get going on ELT wiring: temp mount antenna, will need wings mounted for final installation on all the antennas needs to be really stout - antenna needs to stay attached to yellow box on crash
cut template for remote switch deep research on wiring - verify exact pinouts on male and female DB9 and DB15 connectors existing 8-strand is too short to route through tubing - order a 12 foot piece
power and ground to avionics bus. This is downstream of the master switch. Move the essentials bus power feed line up earlier in the circuit, direct from battery power
