Worked through Chapter 28. I found the F1084's were not included in the kit and I am requesting repalcements from Vans.
I also found the QB factory didn't trim the control column mounts as described on 28-4. They just deburred them and popped them into the airframe.
I don't think this will cause any problem, except for creating a heavier airplane. I might go ahead and trim off the excess weight later when the control sticks are mounted.
