Brief Description: Double Checking work in Section 25
Since this was a quickbuild kit, most of the work of section 25 was completed at the factory.
I started working through each step of the builders manual and then reconciled that step with work that had been completed on the quickbuild fuselage.
I have to admit, I'm pretty impressed with the quality of their work.
I found Section 56 Page 6 Steps 4-7 as being omitted at the factory.
This is the installatino of the snap bushings for wire routing at the main wing spare. I'm okay with that, because I'm going to run some different conduit through those holes. But I also am missing the a wear plate made from UMHW plastic.
