Today I dimpled all of the HS Skeleton Components. I riveted the HS stringer structure. I riveted the Middle 10 ribs to forward spar. I got started dimpling the skins, but I'm only 25% finished with them.
On the topic of dimpling after priming (DuPont VariPrime in my case) it was a non-event.
The act of dimpling did not break the surface of the primer. I'm very happy with the results.
Tomorrow, I will dimple the rest of the skins. Load the skins in the cradle and start loading the skeleton into the skins. Things are moving along very nicely.
Look Ma, No Clecos! - Inner HS ribs riveted to the forward spar.
