Brief Description: 2-Match Drilled Left Horizontal Stabilizer
Match drilled the horizontal stabilizer today. There are several holes that have to be drilled using a #40 bit due to not being pre-punched such as HS-00005 & 6, and the inboard half of HS-702. It was a non-issue though because is was easy to get everything lined up. I used a #40 reamer to do the rest of the holes.
The next step completed was to take the skin off and finish match drilling HS-710 & 714 outboard of the bendline.
Now its time to do it all over again on the right horizontal stabilizer.
