Steves RV-7 Web Site
RV-7
1-Round & Taper HS-710 & 714
Finally, I removed the HS-710 and 714 from the spar channel's and tapered the ends as shown on the plans. I found that my dimple dies worked well again with marking the rounded ends. Had to use the larger set for this though.
Taper Marking
Male Dimple Die
All Done
RV-7 Home
Horizontal Stabilize
Practice Kits
Vertical Stabilizer
