Finished rnchoring the fuel lines. We had forgotten the install an anchor bracket to the wing rib in the right wing. Installing it with the wing mounted was a bit difficult but it is done. Bled the brakes. I had purchased an actual brake bleeder from Wag Aero but apparently it was not compatable with 5606H fluid as it quit working and I found a sealing ring very swollen. Ended up using the old standby pump oil can.
