Brief Description: Finished engine mount bolts and started seating
The lower engine mount plates where drilled for the final bolts and clecoed in place.
Started working on the interior of the plane with the leg rests for the seats put in place. The spar inspection holes where framed with L angle and the four corners had nut plates installed. The right seat was completed today with the left side next.
Lower engine mounts holes enlarged for bolts
Leg rests for seats drilled in place
Spar inspection opening framed (behind) with L angle and 4 nut plates
