Brief Description: Disassembled right wing and deburred and primed
I disassembled the right wing and deburred all the parts in prep for priming. I took this opportunity to remove the nose rib angle that is in place for the short range tanks. As descirbed before, it needs to be removed for the installation of the long range tanks. I used the OLFA tool recommended by Can-Zac and with a few strokes scored it deep enough to be snapped off. I then filed it smooth.
All contact points of the components were primed and set to dry overnight.
Side view of nose rib flange removed for the LR tanks
