Paul's Zenith 601-XL
Date:  2-27-2007
Brief Description:  Final fitting of rear spar and diassemble/deburr/p
Spent an hour re-fitting the rear stab spar to the ribs. Made sure everything was correctly oriented this time! Drilled and clecoed in place. I sighted the skeleton and it looks nice and true and in alignment.Disassembled, deburred and primed the mating surfaces of the stab. Tomorrow I will rivet the skeleton together, and start skinning.
Final fix of the rear spar fitting in the correct orientation
Deburred and primed (still drying)
