Paul's Zenith 601-XL
Date:  4-29-2007
Number of Hours:  1.50
Brief Description:  Worked on small parts for the wing
I didn't get a chance to head out to Home Depot to get the material to extend the workbench so instead I looked through the wing instructions and found parts I could work ahead on. I cut and pilot-drilled the L angles for the spar tips. I also sorted and labeled the nose ribs. The notches for the wing spar was cut in NR#1-3. The holes for the fuel lines were located and cut as well.
The 230mm L angle for the end of the spar tip.  Cut and pilot drilled
Nose ribes 1,2,and 3 with cutouts for spar and holes drilled for the fuel lines
Wing parts worked on this evening.
