Paul's Zenith 601-XL
Date:  4-29-2007
Number of Hours:  1.50
Brief Description:  Assembled and riveted the ailerons
The ailerons were re-assembled and jigged with the washout confirmed. The ailerons were then final riveted on the bottom surface and the trim tab riveted in place. The upper surface was riveted to 4 holes from the front hinge line so it can be opened for inspection.
I now have to take a break from building to extend my table by 4 ft. I also need to get the rest of the kit delivered to the house.
Bottom of ailerons - riveted
Left side trim tab detail with servo installed
Aileron control horns
