Paul's Zenith 601-XL
Date:  4-22-2007
Number of Hours:  1.25
Brief Description:  Prepped parts, made aileron control horns and mach
I pulled out all of the parts needed for the ailerons. I had to make the control horn and while I was at it I made the flap UTP part as well. Since the ailerons have washout built in, I had to machine a piece of pine (from the crating material) donw to 13mm thick. I got to use the Dewalt planer again that I bought for my honey-do projects and made the smoothest shim you have ever seen!
Aileron skins prepped
Aileron control horns completed
furniture grade 13mm shim
