Brief Description: Finished control horn installation , started trim
Slow progress today. I finished off installing the control cluster after retrieving some more "L" from the storage crate. The 6T3-8 strap the ties the upper and lower control horns together was also installed. The skin was opened and 6T3-7 angle was prepped, primed and riveted in place to the elevator spar.
Then it was time to move onto the trim tab. One elevator rib had to be removed and cut to size to allow for the installation of the 6T6-3 elevator channel. This was really a tough job as the parts are a tight fit.
Elevator control cluster
Strap (6T3-8) installed that ties the whole unit together
Trimmed elevator rib and installed 6T6-3 elevator cutout channel
