Brief Description: Cut-outs for trim tab control horns, fitted tab se
The cut-out for the control arm that connects the trim servo to the tab was hand filed out. The trim tab control horn was located and drilled. Finally, the trim servo was located as per the plans and drilled/clecoed in place.
