Had removed the rudder and vertical stabilizer to rivet rudder control stops in place so I took the time to finish riveting and final install on elevator control stops. Drilled #12 attach holes in flap actuator attach bracket and F807 bulkhead. Drilled 1/4 attach hole and final installed attach bracket and torqued bolts Final drilled 1/4 holes in fla actuator clevis brackets.
