Borrowed an angle drill from a fellow pilot and drilled the #30 attach holes in HS to fuselage Final drilled #12 hole and temprarily installed AN310A bolts Trimmed the bottom of VS702 per plans Clecoed the F884 attach plate to the aft side of HS front spar Verfied level on all points and clecoed and clamped Vertical Stabilizer (VS) to the fuselage marked attach holes for rear spar of HS to Fuselage and drilled#30. Final drilled 1/4 inch, deburred and temporarily installed An4 bolts. Used angle drill and drilled #30 the two holes in the F812B-1 control stop and temporarily installed bolts
