Received the 1/2 degree shims from Vans and while I had the wheel pants off bening sanded and primed, I removed the brakes and wheels and removed axles and installed the shims and the fit was exactly what we needed. Installed wheels, brakes, and wheel pant mounting brackets back on the axle and torqued all bolts..
Installed a 1/2 degree tow-in shim on each axle
1/2 inch block in place with fishing line measuring toe-in
