Went out to the hanger today and spent the afternoon fitting the wheel pants. Installed the U808 brackets on the wheel nuts and leveled up. Installed the nutplates and attached both halves on each side per plans. Used a cutting wheel and trimmed wheel opening to fit and notched out for gear leg. Leveled wheel pants per plans and drilled and clecoed the wheel pants to U808 brackets. Will work on adjustments to centerline of wheel pants to airframe in next session and drilled inboard attach holes.
Outboard clecoed
You can see the brackets on the inside that will get a drill hole
