Riveted the F8119C to the F8111 support bracket. Clecoed the F-8111 support bracket to left seat rib and fabricated push tube with cotter pins per plans. Marked and drilled the Friction block and installed nutplates. Riveted the F-8111 support bracket to left seat rib and installed push tube, friction block and attached springs to WD-807 column and push tube. Fitted the F8119A plate to side of fuselage. Drilled and installed nutplates. Installed trim lever and trim cable to F8119 plate and installed plate to fuselage Drilled AN3-5 bolt #44 hole and installed and calibrated trim slide tube function per plans.
