Parts were primed and then fitted F8110 tube guide to right rib. Drilled and clecoed. Dissassembled, deburred, then clecoed back on and riveted tube guide to right rib.
Fitted and drilled the F8111 support bracket to left seat rib using hole template, cleacoed two hole and drilled the remainder. Unclecoed and deburred parts.
