I spent some time this morning researching the bracket that I would need for the alternator. Since my engine is an older engine that was orginally equipped with a generator, it did not have the boss mount option. Contacted Plane Power and found out the Hartzel number, then ordered the case mount bracket from Aircraft Spruce. Installed fuel pump and torqued bolts. Installed one of the KB fittings and one of the fuel hoses. Had to order a KB 090 fitting because Van's only sent a KB 045 and a KB 090T.
