After receiving the Firewall Forward kit, I began accessing the procedures for installing oil pressure fitting and realized the fitting I had in was too small. After fusing some, I spent the day removing the top right moter mount and removed and replace with the new fitting. Reintalled motor mount, torqued and installed new cotter pins. Installed fuel and oil pressure manifold on firewall. Installed oil pressure hose. Installed the two right intake pipes Installed new Skytec starter and spent the rest of the afternoon accessing the needs for the alternator installation
