Brief Description: Priming Horizantial stabilizer and elevator hinges
Today I had time to prime some of the parts prior to assembly. This was probably overkill but I want to make sure all the parts are primed well. The hingle brackets already has a coat on them but I decided to get them all done prior to assembly. It will be a while before they get pain so I want to protect as much as possible. I also did a trial attach in order to find out how much of the horizantial stabilizer would need to be trimmed to allow the counterbalance arm adequate travel. I will trim these points in the next session.
Horizantial Stabilizer rear spar primed and ready for trial assembly
Trim Tab and elevator attach points primed and ready for trial assembly
Portion of horizantial stabilizer skin that must be trimmed
