Installed the elevator trim tab. Drilled and safety wired both the trim tab and elevator hinge. I had to lay out the hinge rivet locations using the rivet spacer tool. I didn't get any pictures of the trim tab installation but there will be a more comprehensive disucssion on the airleron trim tab installation. It's pretty much same same (at least with respect to the trim motor).
