Matt & Val's 650B
CH-650B
6-W-7
L/H aileron Bell crank pivot brackets
Clamped the pivot brackets together to match drill.
located suppport stiffener and drilled
pivot brackets bolted together , located on support bracket and drilled #3
after everything is located, I opened up the holes for #5 rivets
Drilling bell crank pivot brackets
support bracket located
pivot brackets located
CH-650B Home
450
Electrical / Lights
Elevator
84
Flaps / Ailerons
Horizontal Stabalize
Kit Receipt / invent
Rudder Workshop
197
Work benches
Work benchs
Workshop
