Matt & Val's 650B
CH-650B
6-K
Pre install flex fuel line
Tested flex hose in soapy water.
installed hose in nose rib thru grommets.
will attach to tank after it is installed
Can't put hose on tank before install, because of the tight fit between the ribs. too hard to try and snake it in while twisting the tank into position.
Cap & valveinstalled to test
Hose routed thru nose ribs
CH-650B Home
450
Electrical / Lights
Elevator
84
Flaps / Ailerons
Horizontal Stabalize
Kit Receipt / invent
Rudder Workshop
197
Work benches
Work benchs
Workshop
