Matt & Val's 650B
CH-650B
6-K
flex fuel line in right wing
I'm using steel braided flex lines from EARL's to go from the wing tank into the fuselage
Followed Mfg instructions for attachment of swivel seal fittings.
Capped ends and pressurised to test for leaks in a bowl of soapy water
Note, wait for bubbles from steel braid to dissipate
Installing swivel seal fitting
fitting installed
checking for leaks
CH-650B Home
450
Electrical / Lights
Elevator
84
Flaps / Ailerons
Horizontal Stabalize
Kit Receipt / invent
Rudder Workshop
197
Work benches
Work benchs
Workshop
