Matt & Val's 650B
CH-650B
fuel tank ground / sender wires
made a ground point on nose rib # 3. blue tape is holding an edge grommet on the lightning hole to protect the sender signal wire.
I used the nylon sleeving to protect the wires as the go around the edge of the tank
still waiting on the proseal to dry
ground point for fuel tank
sender ground wire attached
sender signal wire and sleeving
CH-650B Home
450
Electrical / Lights
Elevator
84
Flaps / Ailerons
Horizontal Stabalize
Kit Receipt / invent
Rudder Workshop
197
Work benches
Work benchs
Workshop
