Brief Description: Top wing skin stiffeners between ribs
Locating the top skin / bellcrank supports was a chore I wanted to make sure the L's were tight against the skin and the bellcrank support.
i used a few scraps of material to make sre the stiffeners were flush with the top of the ribs when I clamped them to the bellcrank support. I drilled the holes in the support, then layed the skin back down and drilled into the L's
Next: decide if I want to install the Baggage lockers or not.
