Matt & Val's 650B
Date:  10-7-2020
Number of Hours:  1.50
Manual Reference:  6-w-9
Brief Description:  Top Wing skin stiffeners between ribs
If you haven't yet purchased an edge marking tool...just do it already
You don't need it, but it makes the process of marking center lines and rivet lines aa breeze
i removed the clecos from the trailing edge and peeled the skin up to locate the top skin stiffeners
drilled all the holes #40, then will enlarge once all stiffeners are located
using edge line marker
Stiffener OB of tip rib
Stiffeners located #40
