Matt & Val's 650B
CH-650B
Engine prop flange stand
Bolted the support angles onto the engine stand plate
These angles will provide clearance for the nuts & bolts used to hold the engine against the stand.
Drilled holes to match prop flange pattern
Cut center hole to clearance center boss on prop flange
Angles bolted on
holes drilled to match prop
Cutting center hole
CH-650B Home
450
Electrical / Lights
Elevator
84
Flaps / Ailerons
Horizontal Stabalize
Kit Receipt / invent
Rudder Workshop
197
Work benches
Work benchs
Workshop
