Matt & Val's 650B
CH-650B
Engine Prop flange stand
Needed an engine stand to hold the corvair vertically on the prop flange
I had a scrap piece of half inch aluminum plate lying around
so, I laid out the biggest size I could fit within the irregular shape and started sawing off the corners
tapped the edges to attach some angles with bolts
Sawing off excess from scrap
Tapping holes on edges
CH-650B Home
450
Electrical / Lights
Elevator
84
Flaps / Ailerons
Horizontal Stabalize
Kit Receipt / invent
Rudder Workshop
197
Work benches
Work benchs
Workshop
