Brief Description: Cleaning threads & install head studs
I clamped the tap in the vise and used a socket to turn the headstud down the tap. wanted to make sure they would turn on the studs without any resistance
Replacement stock studs and locktite 620 (had to order Loctite on Amazon. none of the auto parts stores around here carried it
Engine block on the stand, with the bad studs removed, ready to install the replacement studs.
