Brief Description: Chasing holes and pulling studs
Using NC tap to chase the holes on the oil pump end of the case.
Need to pull the damaged head studs. place a double nut on the end. Apply a little heat and touch the threaded joint with the candle. Capillary action draws the wax into the threads. Use a socket and breaker bar and the studs came right out
