Matt & Val's 650B
CH-650B
Engine Teardown
engine teardown, pull harmonic balancer
Bought a new harmonic balancer puller. The one I had did not fit the Corvair holes
I sent the HB to DALE MFG to be rebuilt. Much Cheaper than a new one from Clarks.
Removed the bell housing, then removed all the case bolts and split the case.
pulling the HB
Removing the bell housing
Case split and crank removed
CH-650B Home
450
Electrical / Lights
Elevator
84
Flaps / Ailerons
Horizontal Stabalize
Kit Receipt / invent
Rudder Workshop
197
Work benches
Work benchs
Workshop
