Matt & Val's 650B
CH-650B
6W6-10
Aileron Bellcrank Support Channel / rib support L'
Drilled support channel to match RR#7, and located / drilled bellcrank support locations
Cut the support L's for RR 1 thru 4
Marked rivet line on L's and drilled to ribs
Support channel drilled
Rib support L's cut to length
L's drilled to ribs
CH-650B Home
450
Electrical / Lights
Elevator
84
Flaps / Ailerons
Horizontal Stabalize
Kit Receipt / invent
Rudder Workshop
197
Work benches
Work benchs
Workshop
