Finished the A/C hose supports, and worked on the baggage bulkhead corrugations. I had installed these a while ago to ensure proper alignment while working on A/C but there was some slop and I needed to redrill a couple holes, plus drill other holes that were not yet drilled. There is a small overlap at the top corrugation over the A/C exit that I will trim off.
